Behringer UMC404HD
Dan Holuk
Has anyone on this forum used the Beghringer UMC404HD USB Audio interface?
Was having difficulty in getting measurements and they were all over the map
Wayne A. Pflughaupt
Corpus Christi, TX
My AV System
Yamaha RX-Z9 A/V Receiver
Pioneer BDP-23FD Blu Ray Player
Canton Karat 920
Canton Plus D
Canton Plus D
Yamaha YDP2006 Digital Parametric EQ (subs)
Stock Yamaha Remote
It’s a common problem with complex devices. The simple ones with 1-2 inputs and the means to turn off the monitor typically work best.
Zoltan
Hi Dan,
I have a UMC204HD and have started doing some measurements with REW also, I had an issue like you but found it was better by setting the "Phones" rotary knob level to 0 before any measurements.
