Bass Hunters Analysis: Hush, The Shush Cut
Editor / Senior Partner
Baltimore/Washington Metro
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
GoldenEar Invisa MPX
Quad Array SVS SB16s
JVC NZ8
Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Bass Hunters: Hush, The Shush Cut
Infrasonic Bass: :5stars:
Atmospheric Bass: :5stars:
LFE Bass: :5stars:
In this episode of Bass Hunters, we dive into Hush (2016), Mike Flanagan's suspense thriller that has quietly become one of the best bass demonstrations available for home theater enthusiasts. Using professional audio analysis tools, we examine how the soundtrack uses deep infrasonic pulses, textured atmospheric bass, and transient low-frequency impacts to heighten tension throughout the film. From subtle footsteps and door slams to room-shaking jump scares and powerful infrasonic shockwaves, Hush proves that great bass isn't just about loud explosions. It's about using low frequencies to pull you deeper into the story.
The unique "Shush Cut," presented in black and white with much of the musical score removed, puts even greater emphasis on environmental sound design and bass effects, making it a fascinating listen for anyone interested in cinematic sound design.
If you're looking for a movie that showcases what a capable subwoofer system can really do, Hush belongs on your demo list.
You can buy Mercy at Amazon using the following links:
Kaleidescape owners can find the film here:
Note, we may receive a small commission from affiliate links at no additional cost to you.
I absolutely LOVE the mix on this film. and I actually dig the silent (ish) version even more. it makes great use of the weird truth that LACK of sound can just be as impactful as sound itself in setting tone and mood.
It is REALLY good.
@Bright Side HT pointed out that the film was originally released through Netflix and the included (disc) Atmos track is actually based on Dolby Digital 5.1... meaning its a lossy version.
The Shush mix is lossless DTS HD MA 5.1.
To DJ's point, it's probably way more dynamic than the included Atmos mix.
Have you played around with both?
It is REALLY good.
that's interesting. I wonder if it was ACTUALLY based off of a 5.1 DD lossy track and upscaled (or up mixed really), or else it took the same STEMS that the lossy track were from and built the Atmos track frm that. Not sure I remember there being a massive dynamic swing between the Atmos and the Shush mix...but being that the shush mix IS pretty silent (ish), it's hard to give it an apples to apples comparison
Apparently tech info on the disc says the base layer is DD 5.1
This is a great film and very atmospheric. I need to check out the disk version.
Definitely. With your love horror… I think you’ll really appreciate the shush cut!!
So, the B/W is more impactful than the color version?
Visually?
Visually, yes... It's impactful. Tho, I did catch a few moments where the grayscale seemed to instantly switch to a warmer palette. Aside from that, it was interesting!
For bass... not sure. If the Atmos rendering really is based on Dolby Digital 5.1, then one could draw a conclusion that it's somewhat neutered. I can say, for sure, that the DTS HD MA track is not!
