REW Beta Release Acoustic Timing Reference
proper88
Hi,
i generate a measurement sweep file with the generator.
Then i import this file in the "make a measurement " panel. This is not possible because when i choose left channel i get the message
"Data Missing ..."
When i use right channel i get the message
"Sweep missing"
I only want the sweep singal on the right channel und the acoustic reference signal on the left channel, is this not possible ?
Thanks for support,
proper88
In the meantime generate another sweep file with the sweep on both channels and tell REW that's the file to use, while you actually use the one you already generated.
