Hi John, i'm new to measurement.
And plan to do time alignment in my car audio using REW. For the info i'm using full active setup from a DSP.
My questions are:
1. If i'm using UMIK-1 as microphone. Can i get good result for time alignment? Since lot of people said UMIK-1 doesn't have any requirement for loopback ( i don't understand loopback for)?
2. Some said it still can be done using UMIK-1 with timing reference on the measurement menu at REW, if that so how i fill number on the timing offset box? (i put the picture as you can see)
since i saw on a youtube channel the value number fill with -1.8469.
Thank you.
My questions are:
Thank you.
