Socket
- Jul 19, 2020
- 19
Love that REW now allows IR to be measured using USB mic with a acoustic reference timing option, instead of a loop feedback.
But I have run into a problem with V5.20
When trying to do an IR measure using a sweep and ART, it comes back with a "signal at end of sweep could not be detected". At other times there is no signal produced at the start of the sweep, so it just waits, hears the end of sweep signal and then measures?? Is this a corrupted sweep generation file or have I got some setting stuffed up somewhere? I am a novice and would appreciate some help figuring out why REW is not producing a ART signal at the start and end of the sweep.
What makes this more confusing is that I was able to get IR measures yesterday using ART without a problem
Uninstalled and reinstalled V5.20, no change
Rolled back to V5.19 and had the same issue with the missing ART signal at either the start or end of the sweep
Settings
The ART option is ticked in the analysis tab
USB mic (Superlux ECM-999) plugged into laptop and selected as input device (R channel)
Output is blue tooth connection to Helix V8 DSP via BT expansion card (L&R channel) which plays the signal through the drivers selected in the AFT DSP PC Tool.
Timing reference selected (L channel)
Any help would be much appreciated
Settings
