Which comes first, REW or Yamaha YPAO?
JohnGraves
YAMAHA RX-A2070
YAMAHA RS-600
OPPO UDP-203
PARADIGM
PARADIGM CS-450
PARADIGM (IN WALL)
PARADIGM (IN WALL)
PARADIGM & M&K
JVC DLA-X790 (RS540)
VUTEC BRIGHT WHITE 110" 16X9
HARMONY ULTIMATE ONE
ZAPPITI MINI-4K HDR, ZIDOO z9S,
Hi, I'm a newbie. Before running REW should I clear out the PEQ from the Yamaha 2070? Or should I just change the PEQ for the Sub and zero it out before running REW? I'm trying to avoid layering REW readings on top of the PEQ applied by the Yamaha. It's a question of Procedure. Which goes first, and when should I run Yamaha's YPAO? My main concern is bass response. I believe my room is creating major nulls and canceling out bass. (I also have a MIniDSP HD on order). Thanks in advance.
Mike Schramm
Bright Side Crew
Minooka, Illinois
Onkyo TX-RZ840
Emotiva BasX A7
Panasonic DP-UB820
SVS Ultra Bookshelves
SVS Ultra Center
SVS Prime Satellites
SVS PB-2000 Pro (x2)
miniDSP 2x4 HD
Sony XR-77A80J
Logitech Harmony One
Apple 4K
Netflix, Hulu, Apple Music, Amazon Prime
To my knowledge, you would run YPAO on your Yamaha first. Hopefully that flattens some things out for you a little bit. Then you would run REW to see where you can fine tune it even further with your miniDSP. If your sub has it's own PEQ settings (like the newer SVS subs, for example) you wouldn't use them because you have the miniDSP instead.
JohnGraves
YAMAHA RX-A2070
YAMAHA RS-600
OPPO UDP-203
PARADIGM
PARADIGM CS-450
PARADIGM (IN WALL)
PARADIGM (IN WALL)
PARADIGM & M&K
Thanks, I'll give it a try.
