Where do i need to improve sound quality
icckledave
Hi
I am new to the treatment side of a room but i have added Traps/Panels and also treated walls internally.
I have attached the full file for people to have a look at and to get a grasp of things I'm doing correct or incorrectly......the room is 2.2m W x 4.9m L x 1.8m H
If the file is incorrect or there is something missing please let me know
Look forward to hearing your thoughts and guidance
You have some huge peaks in the left speaker... and both seem to be pretty bass shy. I assume your room is not symmetrical.
Tell us more about your room and equipment. I know the speakers are very good and neutral, so unless the speakers are really close to the walls, you probably shouldn't need a lot of acoustic treatment. Check out Floyd Toole's Sound Reproduction 3rd Edition... very helpful in understanding acoustics. I would like look at something to help smooth out the bass response and give it some meat, unless you don't like very much bass.
Like Sonnie said in his reply above.. there seams to be some issues with the left speaker and you could use a little more bass. The right looks great. Also, your decay times are really low... i.e.. very little reflections. That might be good or bad depending on what you are using it for. What is the intended use and what have you done to treat the room? Could you post a diagram or a picture? Are you using a sub? More details on your equipment will be helpful.
