What is a Current great Sound Card for REW ?
Cut-Throat
I have a old M-AUDIO MOBILEPRE USB audio interface (Sound Card) that I have been using with REW --- I've got a Windows 11 Laptop as well as Windows 10. My old sound Card is obsolete and there are no new drivers for my Laptops..... The install CD that came with the M-AUDIO won't run on the new laptops and I am unable to find any software on the internet.... The std windows drivers lets me run on the new laptops, but I get some different results between Win 10 and 11 -- especially when trying to Calibrate the Sound Card ... I Can't do it on Windows 11
So Maybe I should get a more compatible Sound Card that works Great and is supported by Windows 11.
So any recommendations a new Sound Card or Comments on my Old M-AUDIO one?
Most any soundcard similar in function to your M-Audio and compatible with your operating system will work. You might also try a USB CD drive to see if the old software will install on your current computer
Do you have a Brand name and Model of Sound Card that I could buy? Yes, I tried my USB CD Drive and just get a message that the install Program will not run on my Software - Either Windows 10 or 11
