Water fall truncates, see pic
Timebandit2
Powered speakers
Z10 Mixing desk
Presonus Sceptre
Hi there, such a learning curev on thsi REW, great isnt it, but, a few things popping up whe using differnt setings/rooms etc.
Oner thas got me crsatching my head is truncated waterfall display, looks like a mountain slide that that sudfdenly hits a glass screen that cuts it off!
Screenshot attached, any ideas to why this is happening please?
Thanks in advance!
It’s because the graph’s lower axis is set so low. Most residential settings won’t have a noise floor below ~30-35 dB, so there’s no reason to set the graph’s lower limit to 0 dB. Adjust the graph's vertical axis accordingly and it will look normal.
Thanks, I'll check that out later, so many little tick boxes in REW to a novice to learn about!
Hmm...all I can find is the "Set Graph Axis Limit" which deals with hz and spl, can't find any controls for axis?
You're in the right place. dB = SPL. The graph's left-side (vertical) markings are SPL.
Looks like the left window has been altered as well, which is why the response stays level for a while. You can fix that in the Analysis preferences, set it to Hann:
29600
