Hi everyone,
I'm new to REW. I used it a couple of years ago to check my room's acoustics (I run a small project recording studio) I have a UMIK mic with calibration file.
I have "corrected" my room using "other" room correction software and I'm reasonably happy with it.
I like building music gear and I've recently finished a clone of the famous Night EQ (6 band stereo mastering EQ with "air band")
It has a 10k trim pot for each band, and a 50k trim pot for the gain.
The calibration "manual" says to pre-set each trim pot to 5.6k then put all gain knobs to centre or zero gain and "adjust all trimmers to come as close as possible to the original flat curve" and gives me a multi curve REW file (attached) to "match" to.
My problem: I have absolutely no idea how to do this!
How do I set it up? What tone do I use? Do I use a tone?
I'm sorry if this is a big topic, and I know I should really have a full grasp of how REW does what it does and how to leverage that, but I don't, so please go easy on me!
Any pointers as to how to do this would be really helpful. I obviously have a multi-input/output interface so can easily put the EQ in/out through REW which is where I'm guessing I need to start.
Thanks!
jake
Thanks!
jake
