afilipi
- Feb 22, 2019
- Messages
- 2
- Marantz AV7703
- Mackie HR824
- Center Channel Speaker
- Mackie HR626
- Surround Speakers
- Mackie HR624
- Mackie HRS120
- Video Display Device
- JVC RS540
- Screen
- 120 inches
I’d like to measure the response of my car audio system using REW. The problem is that my head unit has no line-in, aux-in, or HDMI-in port, so I cannot use the same procedure I use for my home theater. Following the online help, I have exported a measurement sweep with timing reference onto a USB stick in WAV format, have plugged the stick into the head unit, and can play back the sweep.
The question is, what now? Should I record the played-back signal using something like Audacity and use the Import sweep recordings function in REW? When recording the signal, should I try to maximize the level without clipping, or is there some optimal target level?
What I have done so far is used the Measure function. I checked the “Wait for timing reference” box in the Make a Measurement window and clicked Start Measuring. I then played back the WAV sweep on my head unit. REW "heard" the timing reference and took a measurement. This procedure seems to work (except the dB level is clearly off), but I wonder if the frequency response calculated using this procedure is incorrect and I should instead exclusively use the Import sweep recordings function.
