UMIK-1 microphone with Helix DSP software, help required
Twonks
UK
Hi all.
Not quite sure if this is the right place to ask so please forgive me if not.
I've Googled the question and got a few answers suggesting to change the gain internally on the mic, but am reluctant to do that without understanding more about the problem as mentioned below.
I have a UMIK-1 that shows up in Windows 10 as a -18 db version.
Work well enough with REW and registers levels as needed but, within Windows and in the Helix DSP software, even when shouting about an inch from the microphone it barely registers.
Windows shows a maximum volume of about 9 percent and I can't see anything to adjust the gain through software in the Windows environment.
This means I can't use it with the Helix DSP software in my car as I can't get the volume level loud enough to be of any use and I believe it can't be right as there are multiple speakers and around 2000W in total powering the system.
As it works in REW through WIndows on the same laptop, I am struggling to decipher what is going on.
Please can I ask if anybody has any comments or suggestions on what to do?
I'm not sure what might be happening, but we'll move this thread to the REW support forum and John may know what's going on with it.
I know in Dirac Live software that I use for the miniDSP C-DSP, it has a mic level adjustment, and I would think the Helix would too.
Twonks
UK
Hi and thanks Sonnie.
I'll give it a few days in case John or anybody else knows of the problem.
Failing that I will ask Audiotec Fischer as they are generally very helpful where possible.
If I find anything in the meantime I'll update this thread for others to reference.
EarlK
-This means I can't use it with the Helix DSP software in my car as I can't get the volume level loud enough to be of any use and I believe it can't be right as there are multiple speakers and around 2000W in total powering the system.
Seems simple enough ( meaning; an easy solution should be in-hand ).
Win10 does have a spot to adjust input levels ( for builtin mics as well as USB mics like my UMIK-1, as seen below ) .
There's a separate spot to adjust output levels.
Googling "Win10 sound conrols" should start you off on the right foot.
How-To-Manage_Sound-Settings
Twonks
UK
Hi. Thanks for the reply.
Yes, I’ve seen that in W10 and used it to determine that the maximum ‘volume’ I got was 9 percent when effectively shouting into the mic.
Adjusting that slider doesn’t appear to make any difference. Not sure why a volume level should be used with a microphone input, would expect to see gain or some reference to input - not output.
Will have a further play in the settings after work and see if it makes any more sense.
Volume is used generically to refer to the level controls for inputs and outputs.
EarlK
The underlined words suggest that you've simply been adjusting the output slider ( fader ) instead of the input fader.
Twonks
UK
Ah shucks :hide:
30 years+ playing with computers and sometimes it takes another to point out the obvious :outstanding:
Many thanks, yes I was moving the wrong slider.
Have now found the input fader, set it to 80%, which made a significant difference.
Will test and set it properly in the car tomorrow.
EarlK
Glad it's all working for you.
Don't feel bad ( it happens to all of us ).
I've been in pro audio since the late 70's and there's definitely times I'd like to plant my foot in the software designers ( you-know-where ) because of bad GUI.
Take Care :)
