Turn Your TV Into Wall Art with NextLevel Acoustics New "Audio Art" Speaker System
(February 29, 2024) NextLevel Acoustics has unveiled its latest sound innovation: Audio Art. In the past, we've covered other discrete and aesthetically pleasing soundbar-like systems designed by the company – think Fusion Frame – but Audio Art steps up the design aspect a notch or two, helping to make speakers practically disappear. The system mounts around the outside edge of a TV, stealthfully hiding behind designer grilles married to a custom frame, giving your TV an art gallery appearance and the confidence to blend into any room.
Audio Art is available in two configurations:
  • Art Series LCR (Left, Right, and Dual Center Channels): This version features four ported enclosures, each carrying four 2.5″ long throw woofers and a 1″ soft dome tweeter, positioned along the edges of your display. It supports a recommended amplifier power of 35-300 watts, boasting a frequency response that varies with the display size – ensuring compatibility with displays up to 100"-plus.
  • Art Series Stereo: Tailored for audiophiles who appreciate stereo sound, this version includes left and right sound modules, each equipped with the same high-quality drivers as the LCR.
Customers can choose from over 15 designer grille fabrics and hundreds of Benjamin Moore colors for the frame kit, providing near-limitless design flexibility. And Audio Art isn't restricted to Samsung Frame TVs. You can use it with any display, provided there are no protrusions below the TV, such as an IR badge/sensor, that would prevent the sound modules from mounting flush.
Audio Art LCR Specfications
  • System Design: Art Series LCR with Top and Bottom Center Channel Modules
  • Enclosure Type: Ported
  • Woofer: (4) 2.5″ Long Throw drivers per module)
  • Tweeter: (1) 1″ Soft Dome per sound module
  • Recommended Amplifier Power: 35-300 Watts
  • Frequency Response: Sides: 74 Hz – 20 kHz, Dual Center: 69Hz – 20 kHz (Note: Frequency response varies based on display size)
  • Impedance: Left and Right Channels: 6 ohms, Dual Center Channel: 8 ohms
  • Sensitivity: 89 dB (1 watt/1 meter)
  • Max SPL @ 2M: 98 dB
  • Sound Modules Factory Dimensions: 2.95″ Height x 2.95″ Depth x Custom Length
  • Custom Frame Kit Factory Dimensions: 1″ Width x 3″ Depth (Note: Total dimensions vary based on the display chosen)
  • Standard Finish: Custom grille fabrics and Benjamin Moore paint match included
Audio Art Speaker System - Art Series Stereo Configuration
  • System Design: Art Series Stereo
  • Frequency Response: 74 Hz – 20 kHz (Note: Frequency response varies based on display size)
  • Impedance: 6 ohms
  • Easy installation with a design that complements any display up to 100"+
To learn more or see a design gallery, visit https://nextlevelacoustics.com/product/audio-art/#.
Related Reading:
