Newfiestang50
- Jan 17, 2024
- Messages
- 29
- Yamaha RXV-2600
- Main Amp
- Emotiva XPA-2
- Additional Amp
- NAD 272
- PSB Stratus Gold i
- Dual SVS SB3000
- Streaming Equipment
- Sonos Amp
So as I posted in another thread I plan on using my MiniDSP 2x4HD as a preamp for both my mains and subs (dual SVS SB-3000) with it being feed with a Sonos Port streamer. The mains (PSB Stratus Goldi) are powered with an Emotiva XPA 2. The connection between the Sonos and miniDSP will be via toslink. I've been informed by other forum members that with such a configuraation it is possible to use a wave file for the pink noise and sweeps with a timing reference and play these signals back from my Sonos streamer. That part I have figured out but after that im kind of lost as to the specifics of tuning with such a setup. I am familiar with performing sweeps in REW using HDMI to a reciever.
So a few questions to start:
1. It states that the timing reference must always be played through a full range speaker. Thats understandable but if am taking a measurement for a sub, wont the full range speaker affect the measurement for that sub? I think the answer has something to do with these timing options but not 100% sure.
2. Timing Offset & System Delay, can someone explain that in a more simple approach for say tuning a sub but timing reference sent through L main.
3. The Generator creates the sweeps but are the sweeps required for each main speaker, both, etc? Do I need both full range sweeps and lower freq sweeps for the subs?
As I said in the other post the main reason for trying this configuration is to basically tune the whole system but specifically apply crossover to the main speakers and limit the base output to them and apply a compressor in the MiniDSP. So basically the 4 o/p's from the MiniDSP will supply signal for L&R mains plus the two subs. I currently have everything running with my Yamaha RXV-2600 which is an older receiver and there isnt much configuration in terms of crossover for the mains. It does sound ok but I think i can make everything sound a little better using the miniDSP as the pre amp. I know there are better units for this but i already have it and would just like to try it. Im also interested in getting further education on REW as well so why not try this.
Thanks, any help appreciated.
