- Manufacturer & Model
- Trinnov Audio Altitude Processors
- MSRP
- Altitude 16: Starting around $18,000 USD; Altitude 32: Starting around $32,000 USD
- Highlights
- The Altitude 16 offers up to 20 channels of decoding with Dolby Atmos, DTS:X Pro, and Auro-3D, 8 HDMI inputs and 2 outputs, 16 analog I/O, Trinnov Optimizer with the 3D calibration microphone, and upgradeable 8K video support. The Altitude 32 expands to 32 channels with scalability to 64 outputs, supports Dolby Atmos up to 24.x.10, DTS:X Pro, Auro-3D, and IMAX Enhanced, and adds modular HDMI 2.1 upgrade paths, advanced bass management, and pro tools like the Dolby Atmos Object Viewer. Both models use Trinnov’s PC-based Intel multi-core platform with 64-bit floating point processing, native hi-res playback to 192kHz, and exclusive features such as WaveForming bass control, 3D remapping, and free software upgrades.
- Summary
- The Trinnov Altitude 16 and 32 stand at the top of immersive audio processing, delivering PC-based power, native hi-res playback, and unmatched calibration tools. The Altitude 16 is perfect for advanced home theaters with up to 20 channels, while the Altitude 32 expands to 32 channels and scales to 64 outputs for reference-grade installs. Both support Dolby Atmos, DTS:X Pro, Auro-3D, and IMAX Enhanced, while innovations like WaveForming bass control, 3D remapping, and the proprietary 3D microphone set them apart. Combined with continuous free software updates, these processors remain future-proof investments trusted by home enthusiasts, studios, and pro cinemas alike.
The Trinnov Altitude processor has earned a reputation as one of the most advanced and flexible tools in both high-end home theater and professional audio spaces. From mastering studios to private screening rooms, it’s revered for its raw processing power, unique calibration tools, and constant evolution through software updates. In this new video, we take a closer look at what truly sets the Altitude apart, highlighting five distinctive aspects of the platform that make it unlike anything else on the market.
Rather than a traditional review, this is a deep-dive breakdown. You’ll see why Trinnov’s PC-based architecture delivers unmatched computational horsepower, how its sci-fi-looking 3D calibration microphone shapes precise sound, and what innovations like WaveForming bass control mean for real-world rooms. We also explore why audiophiles and installers alike call Altitude a benchmark in immersive audio, and why it continues to dominate conversations at events like CEDIA Expo. If you’ve ever wondered what makes Trinnov special, or why installers recommend Altitude as the heart of a reference-grade theater, this is the video you’ll want to watch.
If you’re considering an Altitude 16 or Altitude 32, contact our trusted industry partner Value Electronics in Scarsdale, NY.
Run by Robert and Wendy Zohn, Value Electronics is a long-standing, highly respected AV retailer known for its personalized service, expert guidance, and passion for high-performance home theater. They can help you choose the right Altitude model for your system, explain upgrade paths, and ensure you get the most out of this world-class processor.
Call them directly at (914) 723-3344 and ask for Robert or Wendy Zohn to discuss availability, pricing, and installation options.
Trinnov Altitude 16 & Altitude 32 Specifications
Audio Processing & Formats
- Channel Count:
- Altitude 16 → Up to 20 discrete channels
- Altitude 32 → Up to 32 (expandable to 64 outputs via modular design)
- Decoding & Rendering: Dolby Atmos (up to 24.x.10 on Altitude 32), DTS:X Pro, Auro-3D (up to 13.1), IMAX Enhanced
- Upmixers: Dolby Atmos up-mix, Neural:X, Auro-Matic
- DSP Power: Extensive, PC-based Intel multi-core hyper-threaded architecture
- Processing Precision: 64-bit floating point, long-tap FIR filters (65,000+ taps at 96kHz)
- Sampling: Supports up to 24-bit/96kHz (native-rate processing up to 192kHz without downsampling)
- Bass Management: Sophisticated and fully flexible, includes intermediate bass management on Altitude 32
Proprietary Technologies
- Trinnov Optimizer: Advanced loudspeaker and room calibration
- 3D Calibration Microphone: Tetrahedral mic design for azimuth, elevation, and distance capture
- 3D Remapping: Compensates for imperfect speaker placement
- WaveForming: Time-domain bass control (requires multiple subwoofer arrays)
- Dolby Atmos Object Viewer: Yes (Altitude 32)
Connectivity
- HDMI:
- Altitude 16 → 8 inputs, 2 outputs, HDMI 2.0b / HDCP 2.2, upgradable to 8K
- Altitude 32 → Modular HDMI, upgradeable to HDMI 2.1, HDMI monitoring & analysis
- Altitude 16 → 16 inputs / 16 outputs
- Altitude 32 → Balanced and unbalanced I/O, DB25 AES3 configurations
- Network: Dual Ethernet ports, Audio over IP (Altitude 32)
- Other: USB, RS-232, 12V trigger in/out, dedicated mic input (5-pin XLR for 3D mic)
Video Processing
- Resolution: 4K/60Hz, HDR10, Dolby Vision, HLG, BT.2020 color
- Bandwidth: Up to 18Gbps, 24/25/30/50/60fps (up to 120fps HD)
- Altitude 16 → Hardware upgradable to 8K
- Altitude 32 → Modular HDMI design, upgradeable to HDMI 2.1
Control & Integration
- Remote Access: Yes (for integrators and Trinnov support)
- Apps: iOS and Android control apps, web-based interface
- Control Systems: IP, RS-232 integration supported
- User Experience: Setup wizard, professional calibration tools, Roon integration (Altitude 32)
Hardware & Design
- Altitude 16: 3U rack space, brushed aluminum finish, 5.25" x 17.25" x 15.75" (133 x 438 x 400 mm), 33 lbs (15 kg)
- Altitude 32: Modular/scalable design, Intel multi-core processor, manual power switch (110/240V, 50/60Hz), custom cooling system
AV NIRVANA is member and reader-supported. We may receive a small commission from affiliate links at no additional cost to you.
