Audio_Guy_UofW
- Sep 2, 2020
- 57
- Denon AVR-4700
- Main Amp
- Neurochrome Modulus 686 for music
- Additional Amp
- Topping Pre90 preamp for music
- DAC
- SMSL M500
- Computer Audio
- Roon
- Panasonic DP UB-820; Oppo UDP-203
- Streaming Equipment
- Nvidia Shield Pro; Roopiee Raspberry Pi
- Streaming Subscriptions
- Tidal
- PSB Imagine X2T, Magnepan 1.7i (for music)
- Center Channel Speaker
- PSB Imagine XC
- Surround Speakers
- PSB Alpha
- Surround Back Speakers
- PSB Alpha Mini
- Front Height Speakers
- Totem KIN IC6 Slim (Front O/H)
- Rear Height Speakers
- Totem KIN IC6 Slim (Rear O/H))
- 4 sealed subs with 12" drivers custom built boxes
- Other Speakers
- Mini DSP 2x4 Balanced; HD Fury Diva; MSO sub tunin
- Screen
- EluneVision 96" Acoustically Transparent
- Video Display Device
- JVC DLA X500
- Remote Control
- Harmony Elite
- Other Equipment
- Thorens TD-160 Super, SME tonearm, Shure V15 IV with Jico SAS stylus, Arcam rPhono preamp
Hi, I have seen an issue with trace arithmetic. As per a previous post, I have been using |A|/|B| to normalize a speaker response. I have been using the most recent Beta to correct for an import error on sweep import. I recently had a crash when trying to save some jpeg images, to the point where the icon was removed, the executable file appeared to be removed, and I had to re-install from the previously downloaded file.
Seemed to be working OK, but today when I went to generate some new equalized curves, I went through the procedure of subtracting the 1kHz level to get a 0dB normalized curve, then using this to apply |A|/|B| to the measured curve. Instead of making no difference to the curve at 1kHz, it subtracted the original value of the curve. See attached data file. I have seen this behavior before sporatically and relaunched REW. THis time seems more persistent. Any input appreciated.
