Timing reference at end of sweep not detected
davebullet1050
TL;DR The odd thing here - is REW can detect the end timing reference from an acoustic timing measurement when I apply a 1500Hz LR2 lowpass to the right channel, but not a 1500Hz highpass to the right channel (left channel is unfiltered and same in both cases).
My setup is shown below. I am using the Measure from file option in REW, using a 256K 10 to 20,000Hz sweep file generated with REQ, with timing reference added (trim set to either 0.0 or higher = no difference) - 44.1KHz throughout (no resampling)
Scenarios:
1. If I measure the left channel - REW detects the timing reference at end and I get a nice dead straight measurement (i.e. like a loopback)
2. If I measure the right channel with a 1500Hz LR2 lowpass applied - REW detects the timing reference. Note: the left channel is unfiltered
3. If I measure the right channel with a 1500Hz LR2 highpass applied - REW misses the end timing reference (it finds the first one). The left channel is still unfiltered.
Does anyone have anyidea why REW would miss the end acoustic timing reference under scenario #3?
57013
57015
57016
57017
The timing reference is meant to be acoustic so that it can be heard on the measurement input, that's where REW is listening for it. With a wired connection that no longer works. The surprising thing is that it is detected at all when you measure the R channel, maybe there is enough crosstalk in the X6000 for it to be picked up.
davebullet1050
Thanks John. I didn't think the timing reference played on the right channel - only left? when I listen to it - without any filtering at all, I can only hear it on the left channel not the right. Are you saying the timing reference plays on both channels? I thought you had the option of either left or right - not both. I'll try right generation. HEre's what I used to generate the sweep:
57018
davebullet1050
Ok - so that was my problem. I should have added the timing reference to the right channel as that is the one I am measuring - doh!
Interesting point about crosstalk.
If you filter that channel you will still have issues. The only reliable way to handle that would be for REW to listen for the timing reference on a different channel, which isn't supported. I'll have to think about that.
davebullet1050
Wow! Now that is what I call service :) thank you John! I'll look forward to trying that out (donation paid :)
