Hi all,
I have been using REM for over two years in combination with MSO, MiniDSP, UMIK-1 and three subs in my 7.1 system.
Until last Saturday not one single issue ever occured, thanks to you folks and your guides and valuable hints for REW.
What happened:
I got new surrounds and wanted to check the latest meaurements taken Dec 29th to figure out wether the new surrounds need adujstments since they show a slightly different X-over on paper and I had to move the one of the subs.
I was not able to make reliable measurements using an acoustig timing reference since the typical "chirp" at 5kHz was not audible/detectable, neither in the realtime graph nor by my ears.
Once in while a kind of a cranky clicking noise instead totally off the chirp was observed as the timing ref but I did not rely on that noise.
I could verify the old measuremrents and they are more or less the same, but new meaurements for the subwoofers with timing were impossible.
Mostly seen in REM measurement window :.....waiting for timing reference.......
Measurements, sounds sent to the NAD, leveling the speakers all worked but not the timing reference with the nice "chirp".
After 5h of unsuccessful trials, driver/software deinstallation, instaIlation and updates , I gave up very frustrated.
It is the same hardware with the same preferences compared December when I could conduct the last measurements :
HP spectre with Win11, FlexAsio (Asio4all never worked for me), NAD T778, Umik-1, two different 4k HDMI cables.
Well, some Win11 updates were done, though.
I can't enclose any prints from my preferences at the moment but still hope that someone can help me with that missing timing reference sound.
Thanks in advance
Andy
What happened:
Thanks in advance
Andy
