Time Align Tool says the delay between Left speaker and subwoofer is +10ms. B -16ms for LR/Sub, but +10ms for L/Sub and R/Sub. Am I missing something?
donka
Denon AVR-X3500H
Tekton Lore
Tekton Low Profile Center
Wavecrest HVL-1
Polk OWM3
SB-1000
Yeeesh. Sorry about the mangled title y'all. Looks like I can't edit it either. Ah well.
I'm sure I'm misunderstanding something, but I would expect the delay between individual speakers and sub to be about the same as the combined speakers and sub. Here's what I did:
1. Took SPL measurements for L, R, L+R, and Sub.
2. Clicked Controls --> Alignment Tool
3. Selected "Sub" in the first drop-down, and "Left" in the second.
4. Placed cursor at the crossover point
5. Clicked "Align phase at cursor"
6. Repeated 3-5 for "Right", and "Left+Right"
Here were the results:
Speakers being comparedSubwoofer Delay (after clicking "Align phase at cursor")
L vs Subwoofer10.35 ms
R vs Subwoofer10.34 ms
L+R vs Subwoofer-16.39 ms
I assume I should just go with the L+R measurement, but it's such an unexpected result that it makes me wonder if there's a deeper problem with how I'm using the tool.
jtalden
Arizona, USA
Marantz AV7705 Pre/Pro
VTV 6 chnl NC252MP P-amp x 2
Behringer DCX2496 x 2
OPPO BDP-103 Universal Player
DIY SEAS H1456/H1212 Spkr x 5
DIY JBL 2235H 15" SW x 2
JVC DLA-X790R
Da-Lite Da-Snap 39105V - 92"
If you post the mdat file, I will take a look at it and advise.
donka
Denon AVR-X3500H
Tekton Lore
Wavecrest HVL-1
Polk OWM3
SB-1000
Sorry about the delay! I can't seem to find the exact mdat that lets me reproduce the numbers above, but the same effect occurs with this mdat file (individual speakers produce a positive offset, combined L+R produce a negative).
Some relevant info:
1. I use a Denon AVR-X3500H with Audyssey to handle room equalization, crossovers, etc
2. This mdat was measured with the receiver in "Surround" mode
3. "SB-1000" is the sub. "Tekton L" and "Tekton R" are my fronts.
4. My Denon Receiver crosses the fronts over to subwoofer at 40Hz.
Let me know if you need any other info, or additional measurements. Thank you!
  • AudysseySetup_ReferenceEQ_Surround.mdat
jtalden
Arizona, USA
JVC DLA-X790R
Audyssey did a very good job of setting up your system.
The SPL chart and the phase chart are both smooth across the frequency range. If there was an issue related to speaker distance or EQ settings there would be deviations in the charts near the crossover frequency.
I suggest:
  • Change the Denon XO for all speakers to 80 Hz as the Audyssey setting of 40 Hz is very low. This is a common recommendation. Most main speakers are being pushed too hard using a 40 Hz XO. It's possible to use a low frequency XO setting like 40 Hz only if your listening levels do not overburden the main speakers.
  • Confirm that all 5 main speakers are set to 'small'.
  • If you do change the crossover frequency to 60, 70, or 80 Hz or other frequency it is a good idea to repeat the measurements of the 5 main channels to assure the SPL is still smooth in the crossover range.
Comment:
Placing the cursor at 40 Hz, I confirmed your delay findings using 'Align phase at cursor'. The measurements provided here do not meet the requirements for using the REW alignment tool however so those delays are meaningless.
34104
34105
