TedDBayer
- Apr 18, 2023
- Messages
- 3
- Dsr1
- Main Amp
- Hertz power 5
- Hertz mpk 165.3
- JL w3 12
Confused about which type to use. 2 way Hertz speakers, 6.5 mid, tweet. someone told since I'm using JBL Any curve I should type "none", but predicted isnt even close to the curve.if i use " bass limited" the tweeter curve is steeper and eq is different than using "none" but curve is closer.
Mid bass, only "speaker driver" matches, "none or full range" dont match predicted curve..
So what Target Type should i use for tweeter and mid bass when using JBL curve ?
