YC1984
- May 7, 2017
- 5
- Denon AVR-X4200W
- Chane A5rx-c
- Center Channel Speaker
- Chane A2.4
- Seaton Sound MFW-15 Turbo-SS
Hi all - it has been a while!
We just moved into a new house that was pre-wired by the previous owner for home theatre, but unfortunately not in the way I would have done it (as if all audio enthusiasts are the same lol).
There is actually nothing wrong with the wiring per se, but more so the positioning. The setup is such as that he had all speakers wired for a 5.1 setup all at 8’ feet high: imagine left, right, center and both right/left side speakers 8’ above ground (sides are also ~20-30 degrees behind MLP).
I currently have a 3.1 setup (left & right towers, center channel and sub) and would like to add a few channels by using what wiring is already there from the previous owner but not sure what route to go:
- Should I use the front L/R at 8’ high as atmos or front height channels?
- What’s the best option with the side L/R at 8’ high? Use these as side channels or rear given they are slightly behind the MLP?
- I think I will keep my center under the TV but might consider putting in a bookshelf as center and pointing it down towards the MLP if it would be worth it given it is so high up.
Looking forward to your thoughts!
Thanks!
YC
Thanks!
YC
