Editor / Senior Partner
- StormAudio ISP.24 MK2
- Main Amp
- Emotiva XPA-5
- Additional Amp
- Emotiva XPA Gen3 2.8 multichannel amp
- Other Amp
- Denon X8500H
- DAC
- THX ONYX
- Computer Audio
- AudioEngine A2+
- Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
- Streaming Equipment
- iFi Audio Zen Blue
- Streaming Subscriptions
- Spotify
- GoldenEar Technology Triton One.R
- Center Channel Speaker
- GoldenEar Technology SuperCenter Reference
- Surround Speakers
- GoldenEar Invisa MPX
- Surround Back Speakers
- Front Height Speakers
- SVS Prime Elevation x4 (Top Front, Top Mid-Front)
- Rear Height Speakers
- SVS Prime Elevation x4 (Top Middle, Top Rear)
- Quad Array SVS SB16s
- Other Speakers
- Behringer 1124p; Aura Bass Shaker Pros; SuperSub X
- Screen
- Seymour Screen Excellence, Enlightor NEO AT Screen
- Video Display Device
- JVC NZ8
- Other Equipment
- Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Curious to know what kind of surge protection everyone is using?
I've been meaning to move away from sacrificial MOV (metal oxide varister) surge protectors to something along the lines of SurgeX. MOVs can only take one major hit before failure, but also deteriorate every time they take a surge hit. For years I've been using TrippLite surge protectors, but SurgeX, ZeroSurge, and Brickwall all employ similar non-sacrifical technology. SurgeX is expensive, there's no way around it. A six outlet unit can run in the $400- $500 range. I've covered the company for years, and they have this convincing trade show demo that pumps 5500 volts/3000 amps into a an MOV... and it instantly blows. More importantly, the MOV attempts to shunt or redirect as much energy to ground, which isn't ideal for other gear on the circuit. SurgeX (and the other two brands mentioned) absorb the entire blow without flinching, and it doesn't redirect energy to ground. The equipment connected to the SurgeX demo receives the exact amount of power its expecting without fluxuations.
Several years ago, I started a review with SurgeX... they sent me an outlet monitoring device called Envision. It recorded detailed power information about the dedicated circuit my amps are on and ultimately found nothing – zero issues – which probably helped kill the review. ;-). Long story, but after rotating through several different PR folks, SurgeX hasn't been eager to forge forward, which is unfortunate because there's some interesting info to relay (so, while it's shelved, it isn't dead yet).
Yesterday, I decided to finally pull the painful trigger ($$$) and buy new surge devices. Taking into account what I'd want to protect (projector, subs, gear rack), I was looking at several grand in SurgeX products. That's a big hit. So, after doing some shopping around, I took the leap and bought ZeroSurge. I have three 2-outlet 15A models coming direct from ZeroSurge, and two 8-outlet models (6 on switch, 2 always active) from Amazon (which was charging about $30 than the ZeroSurge store). It looks like ZeroSurge is the original patent holder of the technology that SurgeX uses (possibly vice-versa... I've read conflicting accounts), and Brickwall is an offshoot of ZeroSurge (I *think*). ZeroSurge and Brickwall are priced similarly...
Anyhow, I'd love to know what others are using and why (be it budget or performance).
