- Manufacturer & Model
- Status Audio Pro X True Wireless Earbuds
- MSRP
- $299
- Highlights
- Slimmer case and buds, hybrid driver architecture, effective ANC/transparency, excellent app with real-time EQ, class-leading call clarity with SideTone and strong background-noise suppression.
- Summary
- A confident all-rounder with a standout phone-call experience, flexible tuning, and everyday comfort. If calls matter as much as music, Pro X jumps to the top of the short list.
Every company promises innovation, but sometimes progress hides in the smallest detail. The new Status Audio Pro X looks familiar on the surface, yet something about it feels different. After months of real-world testing, that difference became hard to ignore.
At first glance, the Pro X seems like another high-quality release from New York-based company. The design is refined, the fit is smaller and lighter, and the incorporated materials give a reassuring sense of quality. Inside, a 12 millimeter dynamic driver works alongside dual balanced armatures to produce a sound that can be tuned with remarkable precision through the company’s app. The specs read like a checklist of modern features: Bluetooth 5.3 with LE Audio, Auracast, active noise cancellation, and an eight-band equalizer that responds instantly to your adjustments.
But numbers and features are not the story here. The revelation came when we stopped focusing on the music and started listening to something else. In busy spaces, on phone calls, even while walking through trade shows, the Pro X began doing something other earbuds simply fail to do. Conversations suddenly sounded calmer. Background clatter faded away. It was a small change that made a surprisingly big difference.
There are quirks worth noting. The wind noise filter did little to help. Only three ear tip sizes are included. And the deep control options may overwhelm less patient users. Still, when you hear what the Pro X does right, those details fade into the background.
Curious to learn more and experience what we're talking about in action? Watch the video below and hear it for yourself.
Buy the Status Audio Pro X True Wireless Earbuds on Amazon: https://amzn.to/3L8F0rh
Status Audio Pro X Earbuds Specifications
- Acoustic System: Hybrid triple-driver setup with one 12 mm dynamic driver and two Knowles balanced armature drivers per earbud
- Bluetooth Version: 5.3 with LE Audio and Auracast support planned via firmware update
- Audio Codecs: SBC, AAC, and LDAC (up to 24-bit / 96 kHz playback)
- Connectivity: Multipoint pairing for two devices; supports Google Fast Pair and Microsoft Swift Pair
- Microphones: Six beam-forming mics (three per earbud) with VoiceLoom AI speech enhancement
- Noise Control: Hybrid Active Noise Cancellation with up to 52 dB reduction and multi-level Transparency Mode
- Battery Life: Up to 8 hours per charge, 24 hours total with case
- Charging: Qi-compatible wireless charging case
- Durability: IP55 rating for sweat, splash, and dust resistance
- App Support: Status Hub app (iOS / Android) with 8-band EQ, control remapping, and “Find Lost Earbuds” feature
AV NIRVANA may receive a small commission from affiliate links at no additional cost to you. Thanks in advance for supporting our forum!
