Is there a procedure that would allow me to use an SPL meter which has no output in concert with a non-USB sound card to calibrate the REW SPL meter.
I have an SPL meter built into a multi-meter and a microphone with pre-amp.
I have the calibration for the mic (a Panasonic wm61a capsule based mic with preamp that has a fixed gain of about 250).
My plan was to put both in a sound field to establish the 75db measure to calibrate the REW SPL meter using the REW signal generator to create the sound field.
Is there a procedure for such a set up? The signal generator doesn't run in initial tests to just drive the speakers. Do I have to have the mic output going into the sound card input before REW generator will run? Which signal should be use for this - perhaps the 1000 hz sine wave?
I have calibrated the sound card with the loop-back cables and put in the mic calibration file.
Any insights would be greatly appreciated.
Wes
Wes
