Arai Yuichi
- miniDSP DDRC, Accuphase C200X
- Main Amp
- Accuphase D300X
- Additional Amp
- Accuphase D300X
- Sony
- JBL2245/EVM10M/TAD4001/TAD2001
- Other Speakers or Equipment
- Accuphase DF55
Hi, My name is Yuichi Arai
Regarding SPL/Phase measurement, I like to know the way to have a correct phase plot.
In case I put t=o at IR peak, then the phase plot must be correct. I believe this compensate the sound fly time from the speaker to the mic.
On the other hand, there is a Minimum phase button in the bottom of the screen. Does this also the sound fly time offset?
If so, both two phase graphs display the same? In my case, these are different.
Anyone explain the difference between the two method?
Thank you in advance.
