Speaker measurements show 1KHz tone and harmonics
tuga
Europe
Bespoke transistor
Stirling LS3/6
MacBook Pro > CuBox > Teac UD-501
Hi,
This is my first post.
I've measured my speakers and the distortion tab shows a 1KHz tone and it's harmonics creeping out of the noise floor:
25424
Whis is this happening, have I done something wrong?
Thanks,
Ricardo
Are you using a USB mic? Some USB mics show harmonics of the USB 1 kHz frame rate due to supply modulation, though not usually to that extent. If you do have a USB mic are you using a very long cable?
tuga
Europe
Bespoke transistor
Stirling LS3/6
Hi,
Thanks for the reply.
I am indeed using a cheap USB OMNITRONIC MM-2USB mic, the cable is around 1m long.
Best,
Ricardo
P.S.: is there a reason why I can't post links, not even directing to an AVNirvana page?
You may need a few more posts before you can add links, following a spate of automated spamming a little while back.
