First thanks to John Mulcahy for writing such a good software!
The new beta features are very useful.
REW V5.20 Beta 46
1. Importing the baffle diffraction curve generated by VituixCAD cannot be calculated, and it will be stuck at 75% of the progress bar in the lower right corner.
2. When the curve of REW itself is exported as a text file, when Use custom resolution = 48 PPO is selected, an incorrect file will be obtained.
Error importing data,
There will be many out of order lines.
Line has frequency xxx which is not higher than the preceding frequency xxx
The following lines:
Ling frequency
18 51,200.00
130 256,200.00
165 437,000.00
178 512,000.00
290 2,562,000.00
325 4,370,000.00
338 5,120,000.00
450 25,620,000.00
485 43,700,000.00
REW V5.20 Beta 46
Ling frequency
18 51,200.00
130 256,200.00
165 437,000.00
178 512,000.00
290 2,562,000.00
325 4,370,000.00
338 5,120,000.00
450 25,620,000.00
485 43,700,000.00
