Small enclosure for Dayton Audio PS95-8 3-1/2"?
nelc
Linux
KRK 8 G4
Nvidia
Hello there! I have been learning and I've learned a lot in this forum. I already know the basics of REW and I have an UMIK.
I want to show a friend how a speaker that is better than the one that he has sounds. I mean, I want to gift him something that sounds better than the computer speakers that he has.
But the issue is that these speakers seem to need a big (relative, I know) enclosure and the ideal place for him is his computer desk.
Can I use this speaker? If no, which one? What small enclosure type should I use?
My best wishes for all of you.
MacBook Pro, Custom i7 7700k De-lid 2xAsus1080ti GFX Audirvana Studio, Hang Loose Convolver, Pulsar Massive & 8200, LiquidSonics, SoX
QoBuz Studio Premier, Roon, Amazon Prime & Netflix
nelc
Linux
KRK 8 G4
Nvidia
Thanks a lot. This site is great.
About the Open Baffle I could match with a sub-woofer but there's no space for a big table. I've read that you need big area for them to sound good, not sure about the H-shaped ones
Now, I found abut a similar 2.5" drivers and can pair it with two 2.5" passive radiators. I could make a small enclosure with those and experiment.
This will be used at low volume mostly... I guess I can do without a tweeter.
Any pointers will be appreciated.
nelc
Linux
KRK 8 G4
Nvidia
Hello there. I ended up building the speaker. Internal dimensions are (cm) 13W * 23H * 10D. They sound ragged, as if they were broken unless I cut treble. Putting at most 8W to them.
So, learning what a BSC is :-) Thoughts? Same experience?
