Should I calibrated left and right to each other
skywind7
Most of the time speakers in a room left abs right don’t have the exact same response. When using rew for corrections, should I fix the frequency balance from left and right then tackle the general room correction
If by that you mean alter the frequency responses so they look alike, generally not since the response you see is not solely the direct sound from the speaker. If you are referring to adjusting the levels to get a centred image, i.e. balance control, that is less of an issue but if you are centred between the speakers but the image is offset it may be due to differences in the reflections from surfaces close to the speakers which may be better dealt with by treatment to reduce the reflections.
