(December 9, 2025) There’s a certain segment of the audio world that still loves spinning silver discs, and for some of that digitally inclined lot, SACD remains a coveted format. The challenge for them, and others returning to the beloved Compact Disc, is that player support for SACDs is sparse at best. While licensing fees tied to the format are no longer a hurdle, SACD playback still requires manufacturers to invest in dedicated hardware, and much of the industry has shifted tech dollars toward streamers and DACs rather than physical media players. That leaves SACD fans in a tight spot, which makes today’s announcement rather exciting, because Shanling’s new SCD3.3 not only brings a new disc player to market, but it delivers support for SACDs along with a signal path designed to do it justice.
The bad news? It comes at a steep cost. But I suspect hardcore music enthusiasts might be willing to overlook the SCD3.3's hefty price tag because, let's face it, just about everything in the world of specialty audio is far from inexpensive.
If you've followed our Shanling coverage in the past, you'll know its North American presence is handled by Forte Distribution, which also offers US buyers access to delicious audio machines from the likes of Eversolo, Luxin, and Zidoo (just to name a few).
The SCD3.3 is built around two core ideas. First is Shanling’s in-house HD850 top-loading mechanism, a precision-built disc transport designed to handle discs with smooth layer switching, stable operation, and careful mechanical control. Second is a dual-stage audio path that blends a 24-bit R2R DAC with a 12AT7 tube output section, delivering analog punch on the RCA and XLR outputs while preserving full digital flexibility on the rear panel.
Shanling’s R2R implementation uses a second-generation resistor ladder system built from 212 ultra-precision resistors, arranged in a 19-bit ladder with 4-bit compensation. The architecture works with a push-pull differential design, handling conversion before the signal moves to the tube stage. The 12AT7 tubes themselves were originally designed by engineer Dr. Cai Hongren, and Shanling says each pair is tested and matched before installation.
For users who prefer digital output or want to integrate the SCD3.3 into a larger system, Shanling includes an FPGA-assisted I2S output with 10 selectable modes, allowing native DSD output to compatible DACs. The player's USB DAC mode supports PCM up to 768 kHz/32-bit and DSD512, while coaxial SPDIF supports DoP DSD64 and PCM up to 192 kHz. There’s also Bluetooth 5.0 with LDAC, aptX HD, aptX, AAC, and SBC support for wireless playback when needed.
From a usability standpoint, the SCD3.3 is built to feel like a modern component. The chassis is milled from 9.5 mm aluminum, weighing roughly 22 lbs. Control comes from a 5" touchscreen that pairs nicely with a dedicated window that showcases the warm glow of the player's tube array. Shanling’s Eddict Player app is also supported, giving users a second interface option for playback and system control via iOS or Android.
Forté Distribution notes that the player drew strong attention during its preview at Capital Audiofest, which suggests interest is already high among music fans. And those jonesing for a fresh SACD fix will not have to wait long. The SCD3.3 is scheduled to arrive this month through authorized dealers. Just make sure your credit card is primed for action, because the player’s landing price of $3,990 is very much in premium territory.
Related Reading:
