theconqueror
- Feb 11, 2022
- 8
- Denon AVR-660H
- JBL530
Recently refinished a basement room and it has some weird angles to it. Before I get too carried away with anything I'm looking for some guidance on how I should treat this room.
A little bit about it - this is in the basement, so it's studded out with normal 2x4 with 1/2" sheetrock and fiberglass insulation and then behind that is poured concrete. The weird little jut outward with the door in the top right of the diagram is where the boiler is and that area has 5/8" sheetrock and rockwool insulation. The ceiling height in here is 6' 8". The floor is ceramic tile. We have some carpets down right now, but they have no padding underneath them. We have no curtains for that window just yet either because I wasn't sure if I was going to need to make some heavy duty ones to try absorb sound. I'm also planning on building a media console for the TV and have it wide enough to sit the speakers on it as well, that's why everything looks ghetto rigged. The speakers and TV are in their approximate location, but I can still move them. The main listening position will be the little couch/love seat
Receiver I have is a Denon AVR-S660H. Speakers are JBL 530s. I have the matching center channel as well, but haven't hooked it up yet as I'm not entirely sure it's necessary? Subwoofer is a borrowed Definitive Technology SC4000 until I figure out what I'm after.
I took some measurements with and without audyssey enabled. I had a hard time getting it to run all the channels at once, so they're labelled individually. If there are any other measurements or info I could provide, let me know.
mdat file attached but here is a quick preview
