RME ADI-2 Pro with UMIK1 USB mic not working in any REW
Jan Ott
RME Adi-2 Pro
Please how can I set up preferences in REW 5.19 beta on WIN 8.1 and Java 8, when I use RME ADI-2 Pro and UMIK1 USB MIC?
EMU 404USB or Audio-GD DAC19 works well wit UMIK in REW.
It shouldn't need anything special. If you use the Generate debug file option on REW's soundcard preferences with the ADI-2 connected and attach the file here I can see what choices are available.
Jan Ott
RME Adi-2 Pro
it is working now, thank you for help
Marco Stanzani
AM Audio A100M
Rotel
Quad 405-2
Oppo BDP-105D
Dynaudo BM15A, B&W 801F
Dynaudio Countour Center
Dynaudio BM5A
Dynaudio BM9S
JVC DLA X-70
Adeo 16/9 tensioned, motor
I have the same issue. As a general question, if I select audio device I am supposed to use bot AD for input and DA for output so supposedly I need to connect a mic (with preamp) to the AD input of the RME right? So I understand that I cannot use ASIO if a UMIK is used because the ASIO control panel in REW force me to choose ASIO as input device - UMIK is a non ASIO device)
So next question is how do I configure REW for working with UNIK (input) and ADI2PRO (output)?
What is input(outout) 1,2 (OK, this is an RME specific but maybe you can help)
below the debug file
thanks much
SoundCard Debug Data generated by REW V5.20 Beta 19
Running JRE 1.8.0_211 64-bit on Windows 10
Dated: Aug 18, 2019 9:48:17 AM
Input Device: ASIO MADIface USB
Input: 1: Analog 1 (1)
Input Volume: no control
Output Device: ASIO MADIface USB
Output: 1: Analog 1 (1)
Output Volume: No control
Output Mute: Off
Wave Volume: No control
Wave Mute: Off
Sample rate: 192000
0: Primary Sound Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
Line interface SourceDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
0: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
1: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
2: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
3: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
4: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
5: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 6.0206)
Controls[1]: BooleanControl: Mute Control with current value: False
Controls[2]: FloatControl: Balance with current value: 0.0 (range: -1.0 - 1.0)
Controls[3]: FloatControl: Pan with current value: 0.0 (range: -1.0 - 1.0)
Line interface Clip supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
1: JRiver Media Center 24 (JRiver Media Center 25), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
2: Analog (1+2) (RME ADI-2 Pro), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
3: Realtek Digital Output (Realtek High Definition Audio), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
4: Primary Sound Capture Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
Line interface TargetDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
5: Microfono (Umik-1 Gain: 18dB ), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
6: Analog (1+2) (RME ADI-2 Pro), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
7: Port JRiver Media Center 24 (JRiver , Unknown Vendor, 10.0, Port Mixer
Port Master Volume target port
Controls[0]: BooleanControl: Mute Control with current value: false
Controls[1]: FloatControl: Volume with current value: 1.0 (range: 0.0 - 1.0)
Controls[2]: CompoundControl: CD Audio Control containing Mute, and Volume Controls.
MemberControls[0]: BooleanControl: Mute Control with current value: false
MemberControls[1]: FloatControl: Volume with current value: 1.0 (range: 0.0 - 1.0)
Controls[3]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
8: Port Analog (1+2) (RME ADI-2 Pro), Unknown Vendor, 10.0, Port Mixer
Port LINE_OUT target port
9: Port Realtek Digital Output (Realtek, Unknown Vendor, 10.0, Port Mixer
10: Port Microfono (Umik-1 Gain: 18dB , Unknown Vendor, 1.0, Port Mixer
Port MICROPHONE source port
Controls[0]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
MemberControls[1]: FloatControl: Volume with current value: 0.5300069 (range: 0.0 - 1.0)
Controls[2]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
11: Port Analog (1+2) (RME ADI-2 Pro), Unknown Vendor, 10.0, Port Mixer
Port LINE_IN source port
Attached USB devices
ID: 2a39 Product: 3fd2
ID: 8086 Product: 8cb1
ID: 8086 Product: 8cad
ID: 8087 Product: 8009
ID: 2752 Product: 7
ID: 46d Product: c534
ID: 5e3 Product: 616
ID: 8087 Product: 8001
ID: 8086 Product: 8ca6
ID: 8087 Product: 7dc
ID: 1058 Product: 1021
ID: 5e3 Product: 610
Use the Java drivers and select Analog (1+2) (RME ADI-2 Pro) as the output device, LINE_OUT as the output and Microfono (Umik-1 Gain: 18dB ) as the input device, MICROPHONE as the input. You'll need to select the USB input on the RME, of course.
Marco Stanzani
AM Audio A100M
Rotel
Quad 405-2
Oppo BDP-105D
Dynaudio BM5A
Dynaudio BM9S
JVC DLA X-70
Thanks much
It make a lot of sense but still this does not work :(
What about the sampling frequency? I put the same as JRiver ionternal (as specified in the ASIO drivers)
I selected Analog(1+2) in JRiver as output device and it did play (I normaly use the ASIO MAdiface)
I stopped JRiver as a possible troublemaker but this did not help ....
Marco Stanzani
AM Audio A100M
Rotel
Quad 405-2
Oppo BDP-105D
Dynaudio BM5A
Dynaudio BM9S
JVC DLA X-70
OK, if I push 'next' after 'check level' I can hear the tones ... I was figuring out 'check level would have been sufficient for checking levels :)
p.s. maybe this is an area of improvement for the GUI
arne.vanbalgoijen
TEAC
Krell KAV300i
Tried to use ASIO as output today and I still see it is not possible to use that in combination with an USB mike like the the MiniDSP. Selecting Java instead works, but why not support different sound cards for in- and outputs? I am using version 5.20 Beta 38.
Because ASIO doesn't allow that, it only allows inputs and outputs from the same device. ASIO wrappers like ASIO4All and FlexASIO will create pseudo-ASIO devices combining multiple physical devices but there is a risk of underrun/overrun if the devices have clocks that differ too much. Usually works fine though.
