David Gilfillan
- Feb 6, 2019
- 3
Sure much of this has been covered before, but after a search, a few questions I'm not certain about:
What is the relationship between the window length and FFT (or DFT) size in REW?
Can the two be changed independently once an impulse is measured and calculated? (i.e. retain a constant FFT size and change the window length or vice-versa)
Is an impulse zero-padded after the window ends when the window length is smaller than the FFT size? (is this possible)
Can I export magnitude and phase (Bode plot) with a frequency axis and a fixed (known) FFT size?
Can phase be optionally calculated from the window start rather than time 0? This would help with my on-site confusion about arrival time following a review of phase.
Thanks for the fantastic software and all the time that goes into this forum.
