RobertTheBruce05
- Jul 5, 2023
- Messages
- 5
Hello,
I'm having issues with the "Trace Arithmetic" control, specifically the "Merge B to A" option. When I try to merge the two SPL measurements I'm not getting the full response in the new frequency response that's created. Im trying to combine a far field measurement (with IR Window applied) that is 217- 20,000 Hz and a corrected near field measurement that is 20-20,000Hz. However when I try to combine the two measurements the newly created response only goes down to 217Hz instead of all the way down to 20HZ.
Ive attached a screenshot to help visualize.
Any help would be greatly appreciated. I just cant seem to figure out what the issue is...
