The program is being installed normally, but an error appears on the screen at startup. The Measure icon is not active.
Yesterday I spent the whole day dancing with a tambourine around this installation - I changed folder permissions, replaced the existing DLL file with a newly downloaded one, installed various old versions of the program, a new beta version, and the latest Java updates separately from the Oracle website , but nothing has changed. The only thing left on my mind is reinstalling Windows 10.
I'm asking for help.
Message:
java.lang.UnsatisfiedLinkError:
C:\Users\?\AppData\Local\Temp\usb4java8914092527898318661.tmp\libusb-1.0.dll:
Can't find dependent libraries
Stack Trace:
C:\Users\?\AppData\Local\Temp\usb4java8914092527898318661.tmp\libusb-1.0.dll: Can't find dependent libraries
java.lang.ClassLoader$NativeLibrary.load(Native Method)
java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1950)
java.lang.ClassLoader.loadLibrary(ClassLoader.java:1832)
java.lang.Runtime.load0(Runtime.java:783)
java.lang.System.load(System.java:1100)
org.usb4java.Loader.load(Loader.java:356)
org.usb4java.LibUsb. (LibUsb.java:640)
roomeqwizard.HC.A(y:3317)
roomeqwizard.F.E(y:1020)
roomeqwizard.F$3.done(y:936)
javax.swing.SwingWorker$5.run(SwingWorker.java:737)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:832)
sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:842)
javax.swing.Timer.fireActionPerformed(Timer.java:313)
javax.swing.Timer$DoPostEvent.run(Timer.java:245)
java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
Message:
Stack Trace:
