Hello,
So I'm trying to wrap my head around how to best configure REW while using a pair of active Genelec monitors in combination with a Lynx Hilo as the audio interface feeding the Genelec's. The Lynx Hilo I am using contains a USB Card and uses the Lynx ASIO driver for Windows (Windows 11 Pro x64)
I am using the AES Output on the Lynx Hilo >>>>> TO >>>>> The AES Inputs on the Genelec's. Since there is only one physical AES Output Interface on the Lynx (carrying AES channel 1/2 data) that means there is a single AES cable leaving the Lynx Hilo to ONE of the Genelec monitors (lets call it monitor A).
From Monitor A, there is a AES Out/Thru interface which then connects to monitor B to feed the second channel of the AES signal to monitor B.
The channel designations are saved to the Genelec monitors using GLM so each monitor knows whether its job is to be AES Channel 1 or 2.
Lastly, as part of the connection chain, I am using an external Mic/Pre box (Earthworks 1021 ZDT & Earthworks M30) which outputs an XLR Analog signal into the Left XLR Analog Line Input on the Lynx Hilo for A/D conversion
So with that connectivity explanation out of the way I'm struggling to understand how to perform the "Soundcard Calibration" within REW. When I click that button within REW it pops up a message talking about using a Lookback connection. As I read it, my confusion sets in from the highlighted text shown below.
Taking my use case into consideration with an AES Output to a pair of active monitors with built-in DA conversation......where/how on earth does one setup this Lookback connection?
I think I have many questions about this Loopback option, but I will stop here for now to keep each question/issue better separated in my head.
Thanks for any thoughts on how to do this.
