Chuck Gerlach
- Jun 7, 2017
- 111
I have llitte issue with get REW up and running at home, but I also use it when I travel to calibrate other theaters (that typically use a Trinnov) and 100% of the time I have issues getting started. Whle the Mac ALWAYS 100% of the time "sees'" the Trinnov (System Preferences/Sound), most of the time (or maybe all of the time) it is random that I can get sound initially from Audio Midi Setup. Then when that finally works, it is still random whether REW will be able to get audio to work (even after I have set it up in Preferences). So I eventually end up having to restart the Trinnov and/or restart REW and/or restart my Mac - but it is random on which of those activities actually gets things to finally operate so I can do what I came to do. I absolutely LOVE REW (once up and running) but it is always a painful (and usually extended) and very a frustrating experience to get it up and running.
So my question is this. Should the various components be powered up in some special order, or is there some other "process" that will get me up and running the first time, every time?
I typically connect the HDMI to a powered up Trinnov, then to a powered up Mac and then start up REW. But this fails 100% of the time.
I just returned from a 2.5 day calibration trip and probably had to go through this exercise at least a dozen times - easily wasting probably 5 or 6 hours (or more) since I am guessing each time on the best way to get it to work.
Any assistance would be most helpful.
