Rew not recognizing avr
jedel38
marantz emotiva jvc crown
marantz sr6012
emotiva
crown
panasonic ub420
jbl studio530
jbl studio580
klipsch
klipsch
jbl
jbl
svs pb2000
jvc x550r
spandex
Helllo , when I enter into preferences under soundcard, I want to change output device to my marantz sr6012. The only option in the drop down is default device, primary sound driver, speaker (minidsp 2x4hd) , or speaker (2 high definition audio device) . No Option for my marantz. I've unplug/ plug back in, try different hdmi ports, shutdown and restarted with no luck.
Any idea on how to get rew to Recognize my receiver
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
You might need to enter the Windows Sound Settings > Sound Control Panel > Playback, select the HDMI AVR input (be sure it is enabled), set as default Playback device, and set it up for surround (R-click on it, follow the prompts)
