robbnj
- Oct 24, 2022
- 57
- Denon
- Main Amp
- B&O icePower
- DAC
- Denon
- Computer Audio
- JRiver
Hello all, me again. Tinkering, learning, and avoiding the 50MPH winds and negative double-digit temps outside.
I know the majority of users are taming bass frequencies with their setups, but I'm happy with what I've achieved, and am now spending some more time mucking about with my main speakers.
Getting better at taking measurements, interpreting results, learning how changes will sound, etc.
An odd thing that I noticed before, and confirmed tonight: After running my measured curve through EQ, saving the coefficients to a txt file, and importing into my MINIDSP software, it seems that some of the settings are being changed somewhere along the line.
Below is an example of an EQ curve I created for my right main speaker, selectively in the 200-6,000Hz range. If you look closely, REW suggests a correction of -6dB at ~2KHz, but when I look at it in the MINIDSP, it is showing as -3dB.
Same thing for the ~3.2KHz frequency. REW suggests a gain of over 8dB, but REW interprets that to be 5dB.
Anyone have any idea of what might be causing this? My MINIDSP is the 2x4, running the 2x4ADV software. REW version 5.3.9.
'Wondering if I should be manually entering the REW results instead of exporting the coefficients, and importing to the MINIDSP.
Cheers, and keep warm (to all my northern neighbors).
