I'm attempting to integrate two subwoofers with my 2ch audio system using REW. My issue is that when the JAVA driver is selected in the preferences page, I get an error message when trying to select my Brooklyn DAC+ as the output device. I can get test tones to play using the ASIO driver but then I can not use my UMIK-1 as an input device. I tried using asio4all but did not have any luck with that either (no audio test tones)
Error Message:
REW V5.20 Beta 29 running JRE 1.8.0_231 64-bit on Windows 10, en, windows-1252
Message:
javax.sound.sampled.LineUnavailableException: Speakers (Brooklyn DAC+) has no lines available supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
Stack Trace:
roomeqwizard.E.E(y:1682)
roomeqwizard.XG$16.actionPerformed(y:830)
javax.swing.JComboBox.fireActionEvent(Unknown Source)
javax.swing.JComboBox.setSelectedItem(Unknown Source)
javax.swing.JComboBox.setSelectedIndex(Unknown Source)
javax.swing.plaf.basic.BasicComboPopup$Handler.mouseReleased(Unknown Source)
java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
java.awt.Component.processMouseEvent(Unknown Source)
javax.swing.JComponent.processMouseEvent(Unknown Source)
javax.swing.plaf.basic.BasicComboPopup$1.processMouseEvent(Unknown Source)
java.awt.Component.processEvent(Unknown Source)
java.awt.Container.processEvent(Unknown Source)
java.awt.Component.dispatchEventImpl(Unknown Source)
java.awt.Container.dispatchEventImpl(Unknown Source)
java.awt.Component.dispatchEvent(Unknown Source)
java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
java.awt.Window.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$500(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue$4.run(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
Any help would be much appreciated, I am a novice user of the REW software.
Error Message:
Message:
Stack Trace:
