REW having a problem with JRE
BWLF
Hello!
When I first install it and at the first running instance, everything is fine.
When I close the REW and open it again, it gives this message:
REW V5.31.3 running Azul Systems, Inc. JRE 1.8.0_422 64-bit on Windows 10 Locale: language en, keyboard US, windows-1252 at 96 DPI Running in C:\Program Files\REW
Message:
java.lang.UnsatisfiedLinkError: C:\Users\Administrator\AppData\Local\Temp\usb4java1294169267980860280.tmp\libusb-1.0.dll: Access is denied
Stack Trace:
java.lang.ClassLoader$NativeLibrary.load(Native Method)
java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1950)
java.lang.ClassLoader.loadLibrary(ClassLoader.java:1832)
java.lang.Runtime.load0(Runtime.java:783)
java.lang.System.load(System.java:1100)
org.usb4java.Loader.load(Loader.java:356)
org.usb4java.LibUsb. (LibUsb.java:640)
roomeqwizard.HC.A(y:3317)
roomeqwizard.F.E(y:1020)
roomeqwizard.F$3.done(y:936)
javax.swing.SwingWorker$5.run(SwingWorker.java:737)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:832)
sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:842)
javax.swing.Timer.fireActionPerformed(Timer.java:313)
javax.swing.Timer$DoPostEvent.run(Timer.java:245)
java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
Any help?
java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
