REW EQ - miniDSP 2x4HD vs. DDRC24
Ausmith
I've been using an older version of REW and a Minidsp 2x4HD for quite some time with very good results. I recently upgraded to a DDRC24 because I wanted to fool around with the DIRAC functionality. My question is what is the correct "Equiliser" choice to use with the DDRC24?
I assumed that choosing 2x4 HD was correct, but I can tell you that the EQ parameters did not work as predicted. I seemed to get the best results with the standard miniDSP setting, but neither seemed to be as good as my previous set-up. I did also upgrade my REW version to the latest Beta version.
Any thoughts or suggestions?
Thanks in advance.
DDRC24 does its processing at 48 kHz, so an equaliser operating at 48 kHz needs to be selected. The sample rate is shown in brackets after the equaliser name in the title of the equaliser selection panel.
