Super Panda
- May 15, 2025
- 1
Hello, first post.
Today I was working on REW as per OCA's instructions here:
A few observations on making these filters on MacOS for MiniDSP, please correct me if I'm wrong. I'm decently technically competent but new to REW and DSP.
I'm running a 2.1 system with a MiniDSP Flex Eight into a DSP-sub (DSP settings bypassed obviously) and an integrated into passive speakers.
First, the MiniDSP seems to only accept .bin files for FIR and REW has no export options for such, only .wav. Now, using Finder, I can replace the .wav extension with .bin and choose 1k sample count (MiniDSP supports up to 4096 taps in total, or 2048 per channel). A 2k sample count exports 2060 taps which exceeds MiniDSP's max tap allocation. Doing this, I was able to load the file onto the MiniDSP with the result that my sub, which I had inadvertently forgotten to switch off, started blaring a very high SPL noise / rumble. This was obviously not the right approach.
Second, the MiniDSP supports a manual approach to FIR filtering via text field. Exporting the impulse response as text from REW generates a ~1,5 MB file with ~500k lines (or taps?) which again exceeds the MiniDSP's max supported number of taps and there's no way to select a lower tap count upon text file generation.
Thanks in advance for any possible input
