Schrodingers cat
- Oct 3, 2023
- 2
- Computer Audio
- BEHRINGER UMC404HD
- Other Speakers
- PureAcoustic STS-0.5 soundbar
- Other Equipment
- PreSonus PRM1 microphone
Hello everybody.
I new to using the REW software .
Basically I am using it to some acoustic measurements.
I have some basic question as follows:
1) should I do the level check in the "Preference" window every time I change my microphone position?
2) Why when doing the Level check the Input level should be -18dBFS and not -12dBFS and output around 75dB SPL?
3) As I understand the FS is 1Vrms as default. As I understand during the sine sweep in the measurement window
when I set the sweep level it will be constant through all the frequencies. And the length will determine in what frequencies steps
the sine sweep will be set. Did I understand that correctly?
4) This question is more broad but can I determine the SPL level of my output during the sine sweep?
Thank every one in advance for answering .
Have a great equalization
