REW Automated with Turntable?
ssashton
Hello!
I know that REW has the option to run multiple measurements and attach a unique name to them, such as 0 degrees, 15 degrees, 30 degrees.
www.roomeqwizard.com/help/help_en-GB/html/makingmeasurements.html
I plan to build a turntable for the speaker that can automatically increment the angle (driven by a stepper motor connected to a 3D printer control board). Can anyone help me with how I might get REW to trigger the turntable to increment between measurements?
I guess I could do it simply based on timing but that seems kind of clunky and I'd still need to sync the turntable with the start of the measurement routine.
I can share the CAD drawings and wiring for my turntable if anyone wants it (once I make it work).
Ideally, it would be awesome if REW could output user defined commands on a com port (thinking USB to UART, FTDI FT232 or similar). That way it could push Gcode commands to the 3d printer control board directly to move X, Y, Z axis a relative distance.
Thank you!
