REW 5.40 beta 104: Measurement - frequency scaling issue
ska
Hi John,
Recently I tried to measure frequency response of my DAC at 44.1K SMPS using the latest REW beta version.
I noticed strange droop of the response starting from 18K. Then I switched sampling frequency to 48K and response became exactly like simulated for 44.1K.
In order to proof that the problem is in the REW software, I thoroughly measured the amplitude at 44.1K by digital oscilloscope. The real response was flat to 20KHz, as predicted. Please check frequency scaling in Measurement. Looks like frequency scale is a bit shrunk, like if you multiplied by (44.1/48) twice for shifting from 48K->44.1K.
Regards
REW can only control the interface sample rate if you use ASIO or WASAPI Exclusive Java drivers (device names starting EXCL). If you use the standard Java drivers the OS will resample the data to the rate in REW if the device sample rate is different and you will see the effects of the resampling.
