red5 audio
thomas larsson
hey!
was woundering if this mic will work whit REW, and if there was a eq in REW that fixes the problems in your room?
it seems like a nice program but does it fix the problems that show up or does it just show you the problems?
might be stupid questions but hey... couldent figure it out
tried to post link to the mic but they said i couldent becouse i am new here...
Red5 Audio RV200 Measurement Microphone
is what it is
hope to get some feedback on this, looking at sonaworks to but this is cheeper and i am boroke haha
That mic doesn't appear to come with a calibration file and the response starts to go a bit awry above about 2.5 kHz from the plot provided (with unspecified smoothing). Probably OK if you don't pay too much attention to the results above a few kHz, but as it is a phantom powered mic you would need an audio interface with a mic preamp and phantom power. Might be cheaper overall to get a USB mic like UMIK-1.
REW makes measurements and can suggest settings for equalisers but doesn't apply any EQ itself.
