NullMember
- Aug 4, 2023
- 3
- DAC
- UMC404HD
- Presonus Eris E4.5
Hi all,
I wrote a little python script to generate EQ preset files from REW EQ output file (unformatted text). Pro-Q 3, ReaEQ and ReaFIR supported. ReaFIR preset file generation is useless for this purpose but preset generator library I wrote supports it so I've included it in script. You need to set eq_mode, input_filename, output_filename (without extension), and placement (for pro-q 3 only) variables before running the script. Also, EQPreset library should installed using pip. To install it using terminal:
Here is the link to the script
(sorry for breaking new user URL rule of the site)
Also, thanks for this awesome software and community. I've learned lot from here.
pip install git+https://github.com/NullMember/EQPreset
https://gist.github.com/NullMember/2dcdefdd6f9ec90f21a86183e249bd7c
