My goal is to test the efficacy of convolution files in HQ Player. I've setup my measurement system which consists of a MacBook Pro, Focusrite 2i2 (Gen 2), and a Dayton Audio EMM-6 (calibrated). I'm measuring a 2.2 channel system (two satellites and two subs). Using the loopback timing method and the Focusrite as the signal generator, I'm able to get accurate, repeatable measurements of each speaker. Below is an example of the right satellite using loopback which provided spot-on distance measurements of 4.13 feet (green), next is the measurement taken using the acoustical timing reference (gold) which yielded identical frequency response but no distance results, and the last measurement is the same sweep played through HQ Player via an 80hz high pass and low pass filter to the right satellite and sub playing the sweep together. I'm also getting the same exact results (acoustical timing reference) with a UMIK-1. I'm stumped - would be appreciative if anyone has any info on what I might be doing wrong with the acoustical timing reference here?
