Problem with two-channel measuremente
vadimal12
Hello! version 5.20.14. - previously everything worked fine. But, it is not clear for what reason I cannot measure now with "use loopback as timing reference". There is no "ref output" master pulse. Moreover, in the "use loopback as timing reference" mode, everything works fine.
vadimal12
It used to work for me too ))).
vadimal12
Да, потому что, когда я измеряю акустически, главный импульс поступает на канал L
vadimal12
Yes, because when I measure acoustically, a master pulse goes to channel L
The loopback gets the same sweep signal as the measurement channel. If you are not seeing the signal on the R input there's probably a problem with the connection.
vadimal12
The loopback gets the same sweep signal as the measurement channel - yes.
but after all, when measuring "use acoustic timing reference" everything works correctly. When measuring "use loopback as timing reference", I do not make any changes to the switching (and I do not change anything from the hardware).
vadimal12
Yes, I have installed it, I take the feedback signal from the speaker terminals
Are you taking it to the correct place? Acoustic timing reference listens on the measurement input, loopback timing reference listens on the reference input.
dcibel
Question is simple, where does the loopback wire go?
Input is a USB mic, single channel device.
CAAudiophile
Not sure what soundcard your using but if you are using Focusrite it has 2 inputs l & R and 2 outputs L & R so when using the timing reference loop for example you select the L input and connect it to the L output that would be your timing reference loop. Now the R input will be your MIC and the R out put will be to the speakers/preamp. Hope this help.
vadimal12
Behringer UMC202HD. thanks, everything is already working as it should.
